Blew a headgasket. rant.
nisreo
178
Yea so just my luck, fun ford is in a month and I was hoping to have the mustang on the road and running well enough just to drive it and take it down the track a couple runs this year. Just to have some fun with it before the teardown this winter. Doesn't look like thats going to happen now.
I pulled the throttle body off and brought it to work to throw it in the parts washer, cleaned it all up nice nice. Put it all back together with a new gasket then a few minutes later white smoke starts pouring out of the tail pipes. Shut it down and pulled the dipstick, milky goodness.
So looks like shes going under the knife sooner than I had thought. Im pissed, but then again whatever, **** happens. Tune in to follow the progress this winter, Im sure Ill have a few questions and Ill be making some nice picture filled tutorials (as if there weren't enough already)
Maybe some day Ill get to drive a fox that I own.
/rant
/rant
we did head gaskets on a 91 two weeks ago...took us 6 hours from start to finish with it being our first time doing it...
its not that bad...just take your time...
You think that's bad...
I was testing out my new transmission after a 27-hour (total including undercarriage cleaning, various crap, external cooler setup, running to the store, running into stupid problems, etc.) installation, and raised a head off the block 1.5 days away from my dyno tune appointment!
Thankfully I had it towed to a friend's garage and we tore it down and put it all back the next day, timed it the morning after, and was off to the dyno to shred a blower belt :rlaugh:
Anyway, just sayin' it could always be worse. Be glad it was now rather than a week or so out from FFW :)
Well, the motor is all back together. I ended up taking everything to work and cleaning and painting it. All new top end gaskets and valve seals. lapped the valves blah blah.
Put it all back together, and its not running so hot. I pretty sure my cats are clogged from all the coolant and other crap that it was burning before. After about 20 mins of idleing, my drivers side cat is cherry red, pass side is normal.
The smoke is all gone now, but its still idling at 2000rpm and is lacking power.
could clogged cats be the cause of all this?
hey, at least the top end looks good.
In my experience plugged cats will also make the car not even run past an idle. Can cause different reactions, but it never hurts to eliminate em... :)
OT: hey 88gt, looks like we have the same color, do you know the name of it? I cant read my tag on the door, its been painted over.
when i painted my engine bay i had it color matched and the color says "passion rose" lol. the previous owner repainted my car so i don't know anything other than that
