Blew my t-5..
  • Thread starter Thread starter Matts89Notch
  • Start date Start date Aug 2, 2007
First Prev 2 of 2
M
Matts89Notch
62
#21
  • Aug 8, 2007
  • #21
Well thanks for the help guys but I just got a new tranny for $850...well a remanufactured one. It has a few little things that should make it hold my near stock power levels like nothing.
For me getting the t-5 out today was so easy. I used a jack to support the crossmember as I unbloted it and after I had the tranny unbolted from the motor I just had my girlfriend pull out the jack and I just pulled it out...the thing weighs 75lbs.....thats nothing it was so easy..
On another note the tranny has a few little goodies like hardened gears, the .68 5th, 2.95 1st, and the steel bearing retainer. It has 0 miles on it and I can't waite. I saw summit racing had the OE t-5 for about $2000 but I know for that mooney you can go tko....I'm happy and I will have the car running asap. I feel broke now dumping $1200 into lol Not really but it will be a fun car with the new pro 5.0, kc clutch, and this fresh t-5...
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Aug 9, 2007
#22
  • Aug 9, 2007
  • #22
If you blew 3rd, more than likely the countegear is mangled as well and the peices prob took out a few other parts. That's what i call a catistrophic failure where it just pretty much takes out the whole transmission. There are more bad parts than good.
Toss it in the classifieds as a parts tranny and see if you can make $25-50 out of the day. People like me scoop em up and try to make 1 good trans out of 3-4 bad ones.
1/4 Horse
577
Bear, DE
Aug 9, 2007
#23
  • Aug 9, 2007
  • #23
Not sure where you are located but Bob Hanlon from Hanlon Motorsports used to buy messed up t5s. What's trash to us is a few usuable parts to him. He would probably give you a few bucks for it.
tjmaxx
157
#24
  • Aug 10, 2007
  • #24
Matt get your car put back together. We should go to RSD on Friday the 17th
M
Matts89Notch
62
#25
  • Aug 10, 2007
  • #25
If i get all my stuff in time hopefully mon/tuesday of next week. I think I can do it.
I just won a alum. driveshaft for $160 shipped so thats going on the car also. My clutch should come in today but I still have to remove the bellhouseing and the clutch thats on the car still.
You should see the car right now, it looks like a monster truck lol....with the tranny, ds, and exhaust out, the space in the wheel wells looks really bad...and I thought it looked bad b4..
The car should feel a lot better after the new parts are on. I can't waite..I have yet to feel what a hard shift into 2nd is like...
M
Matts89Notch
62
#26
  • Aug 12, 2007
  • #26
The bellhousing is off and so is the clutch..The only hard part was getting the top bolt off the starter. It took some grunt and I hit my hand hard when it broke loose...
The clutch seems to be in decent shape, it never slipped or anything. I'm just replacing because it's all apart anyhoo. I think it's a stock unit because of how easy it went to the floor. I think it said velco or somthing like that with blue springs...
Tomorrow Some parts should show up and hopefully go on the car....tranny is comming wednesday so I still have to waite..
What fluid do you guys run in the t-5...I know atf.....
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Aug 12, 2007
#27
  • Aug 12, 2007
  • #27
I run conventional Dex/mercon 3 ATF
M
Matts89Notch
62
#28
  • Aug 13, 2007
  • #28
Can you use any atf?
First Prev 2 of 2
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
