Blower cam
N/A cams generally have a lot of duration on intake and exhaust and a lot of overlap, i.e small LSA 112 or less.
Blower cams have a lot of lift and less duration (maybe a little more on the exhaust) and a LSA typically 114 degrees with less overlap, why?
Blowers push a lot of air into the cylinders, there is no need for the intake valve closing much later like the N/A cams (to promote air packing in the cylinders). And smaller overlap because you dont want to blow all that precious boost out the exhaust valve.
I am running an E cam with a novi at about 6-7 psi.
How can you figure LSA? That is lobe seperation. Right?
E cam = 220/220* , .498/.498 lift @.50
F cam = 226/226* , .512/.512 lift @.50
I'm not sure if i can run an F cam. Too much lift?
Going by what was said about lower duration and higher lift, looks like the X cam would be a better blower cam than the F cam. Right?
X cam = 224/224* , .542/.542 lift @ .50
I just dont get cams. :shrug:
Thanks
Thanks
Both the F and X cam i would not recommend for a blower because of the large durations. Sure you could use it, it would actually work great on a 1000+HP engine, but for engines typically making 400-500 HP a blower cannot take advantage of the large duration NA cam.
An E cam with 1.7 RR in my eyes would be a good blower cam setup.
I have a custom FTI blower cam that I got for a customer who decided to go a different way. 50 state emissions legal, and would work very well with that combo, only issue you may have is spring pressure.
$325 shipped
RacEoHolic330 said:
anderson ford motorsport b-31 cam for 1.6 rr's. I have it and I love it..makes great power.
I have the B-31 in my blown 331 and it is a pretty decent cam. In my 331 with TW heads, E-brock RPM intake, 3.55 Aod'ed car, it pulled to an 11.19 with stock EEC. And that was on 17" Mickey T drag radials, at a race weight of 3450... All in all I say it is a pretty decent cam.
But for not much more a custom cam would be the way to go. I have been debating about swapping to one while my motor is out though.. Just haven't made up my mind on that yet. I can either swap to a custom cam or swap to a long tube set-up... Just haven't decided yet..
:OT: Myke86GT, what size injectors are you running?
I am thinking about purchasing a 347. I am running 30's right now. I think that i will need to upgrade to 42's. I have been reading about the tweecer and pms but dont really want to get involved in messing with the computer.
thanks......
5.02go - you don't 'figure' LSA -- it's ground into the cam -- your Ecam has a 110 LSA.
If you want to learn more about cams and how they do what they do, go here -- http://www.wighat.com/fcr3/ -- open every tab and read. And btw, with a boosted 347 that needs 42's -- it's likely that someone (you or someone you pay lots of money to) is gonna have to 'get involved messing with the computer'.
thanks......
I run 42's with a 255 HP intank, with a t-rex and 40#'s fuel pressure, plus all this was on stock EEC. I know I need a chip or something, but didn't at the time..
