- Nov 26, 2005
- 100
- 0
- 0
the car is an 85 gt with a kenne bell and its headgasket is definitely blown and now i need to figure out what to do next. it was running 5-7psi, then my dad and i switched it to 9-11psi, then back to 5-7 because we noticed alot of pinging with the 9-11, and then realized it was blown after switching it back. we are not sure wether it was the extra boost that blew it, or that it was blown for quite some time and we never really noticed(realitively new-to-us car that sat alot with previous owner and when we got the car one plug wire was completely burnt apart by header). should we just get a nice headgasket, run the 5-7psi, slap it together and call it a day? i would love to run it at 9-11psi but am afraid that it will blow agaian. can i safely run 9-11 psi? do i need to o-ring the heads? i know the motor has about 30k on a 89 block, the original kenne bell, ported gt40 heads, msd ignition, boost-a-pump, bigger injectors (they are black, im not sure what # they are), mass-air conversion with stock ecciv, and some other things i might be forgetting or dont know about. i wish i knew more about the motor but ill try to answer everything i can. thanks in advance
