95mustang_gt said:
well this is one of the combos i was thinking of going with
my cobra intake
TFS Twisted Wedge Aluminum Heads
75 pro-m maf with 24#inj
Not sure on the cam,which one will be good with this combo
I look into the other post and i like what 94-302-vert had to say about making it a solid car first and then go with the big stuff.right now i have 1700 to spend,how much im I looking to spend with the combo above.
Or
i do wheels,and suspension,all fuel and ign components and fix up some bugs .Will a tweecer do me any good at this point?
Right now im runnig a 14.6 at 96 with a 2.2 60ft is that good for my mods or should i be lower?
thanks for the advice so far guys
thanks
Jesse
Don't forget that with TFS heads you are forced to use stud rr's so having said that you also gotta use new pr's so don't forget to figure that into the mix.
AFR heads will allow you to use ped's which could save you money. Not sure if you have the ped option with Edels. I prefer studs anyway so to me its no big deal.
I just wanted to point that out if you had not thought about it.
I'd pick the 80mm maf over the 75 even though the cost is a bit more.
You're gonna need a bigger intank pump.
As for a cam, lots of choices. Several have done well with 2031, TFS stage 1, etc. Crower cams can make good power but they are so pricey you might as well go Custom.
Not too sure $1700 is gonna take you as far as you think if you go with new parts. Don't forget you gotta have gaskets, anti freeze, oil, oil filter, and all that piddley stuff.
I know it won't get the job done if you gotta pay for labor.
You'll just have to add it all up real good
Grady
