Blowing coolant, overheating HELP!
FSTRDNU
76
i just installed new mls headgaskets, and everything seemed fine. but twice i floored it, and banged a couple gears, and i smelled coolant, and my temp gauge rose QUICKLY to HOT, and i blew the hose of my overflow bottle, and coolant was everywhere.
anyone ahve any ideas?
Also if you didn't have the heads properly surfaced that could have caused it as well. Running Cometics and the heads need a finer finish, almost polished to seal properly. Also you are supposed to retorque the heads I believe afetr a couple of heat cycles. Good luck.
Do the obivious - do a compression test. Either a leak down or regular compression test will tell the story. See my website for details on building your own leak down compression tester.
It seems like his symptoms are under boost only. A leakdown test might not reveal any problems because it cant reach such high pressures. It's worth a shot tho.
