Blown Headgasket?
945.05spd
ok ive had mustangs since i was 16 i know wat to look for when buying one
i just bought a 94 5.0 5 speed yesturday i test drove it everything was fine..but now when i start i get big cloud of smoke for a few seconds smells like burnt oil and another time while i was driveing i looked out the rear window and i realized i was leaveing a smoke screen behind me its only done that once the antifreeze is brown too...i hope its not a head gasket cuz i just exhasted my bank account to buy this stang.because i was walking and riding my bicycle everywhere.i could do the gasket myself if i had the tools and the ability to finish it in one day....any suggestions?
You don't necessarily have a blown head gasket. You could have a worn out motor. Look at your engine oil by pulling the dipstick. If it has a chocolate milky fungu on the stick, then maybe you have a blown head gasket.
If your engine oil looks normal (even if it's dirty, and needs changing) then I'd say you got a problem like bad seals/guides in the heads.
Smoking on start up, and smoking on deceleration is a pretty good indication of that. How many miles on the engine, does it have an automatic transmission?
Actually you'd prefer having a blown head gasket since it's just time plus $40 for headgaskets. However it could be the piston rings (motor) shot like Mike said. Then you'd be looking at a new block. You can pick up an Explorer motor for couple hundred and swap that over. Or just buy a new block and swap it with the worn one.
its actually much more then that
2 head gaskets from fel pro- 65-70 bucks
intake gasket set- 12 bucks
exhaust manifold gaskets-15
felpro head bolts-20 bucks
valve cover gaskets- 12 for cork 31 for rubber
plus you have things like coolant
thermostat and gasket
oil change or 2 to flush everything out of the system
and anything else you do while your in there.
if you do it on the cheap your looking around 200 bucks
The mix may look something like this...
