  • 1994 - 1995 Specific Tech
Bogging, so I pulled codes. Take a Look.
  • Thread starter Thread starter KBCobra95
  • Start date Start date Jul 14, 2006
KBCobra95
356
North Carolina
Jul 14, 2006
  • Jul 14, 2006
I have been having this bad cold bog lately. I have replaced the ECT and cleaned my ACT. None of this worked so I decied to pull some codes:
116: ECT sensor is out of Self-Test
311:Secondary air injection system inoperative during KOER self-test (bank #1). - Deleted smog pump
314: Secondary air injection system inoperative during KOER self-test (bank #2) - Deleted smog pump
327: PFE sensor circuit voltage below self test minimum
511: ROM test failure
The last one is kinda scaring me since I just had a dyno tune 2-3 weeks ago. What is the PFE sensor? And also, when I changed my ECT sensor, I was expecting coolant to gush outta the hole, but there was none? Maybe because it was cold? Please help!
1TallMF
955
Montreal
Jul 14, 2006
  • Jul 14, 2006
Couple of things:
Did you disconnect your battery to reset the computer after you replaced the ECT sensor? This could be an old code. If you do this and the ECT sensor code comes back, check the OHM reading of the sensor when it is cold and also when it is hot. I forget what the resistance values should be, but someone hopefully will chime in.
Secondly, if the engine is cool, there isn't very much pressure built up in the cooling system, and the ECT sensor sits near the very top of the flow path of coolant. I lost maybe four drops of coolant when I changed mine.
Code 511 seems to be quite common for a chipped car. I can't remember what PFE stands for, but again, hopefully someone will chime in.
gcomfx.com
3,690
Republic, MO
Jul 14, 2006
  • Jul 14, 2006
Yup, last one is common, just means you have a chip in the car. :wink: The others, not too sure about but 1TallMF is right, clear the codes, and drive it some more. See what is CURRENTLY happening to the car.
HISSIN50
34
129
Jul 14, 2006
  • Jul 14, 2006
PFE/DPFE is the EGR monitoring system as I recall.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 14, 2006
  • Jul 14, 2006
YEah, code reads "EGR circuit is below minimum voltage"
Scott
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
A
Resolved 1989 Mustang bogs down after 3-5 minutes of driving.
  • Alabama
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech May 26, 2025
limp
