One brake manufacturer breaks vehicles down into generations to illustrate how much brake systems have changed:
Traditional RWD (say, an '80 Caprice): 22 lb. rotor, large friction area, average surface temperature of 350 deg. F. Also, a non-overdrive trans and a boxy body (in other words, the car slows down when you take your foot off the gas).
First Generation FWD (the GM X-Body, for instance): 12 lb. rotor, average surface temperature of 500 deg. F. Low performance, no overdrive, and still boxy.
Second Generation FWD (Lumina, Taurus, etc.): 10 lb. composite rotor, average surface temperature of 800 deg. F. Now, you've got overdrive, V6 and multi-valve performance, and an aerodynamic design that not only lets the car coast farther, but also cuts air flow to the brakes.
Third Generation FWD (we're talking Chrysler's LH): The rotor's back up to 12 lbs., and the cab-forward, longitudinal engine design means this is another whole animal. Data is still being compiled from testing and real-world experience, but you can bet these cars will need their own special semi-met recipe.
