  • SN95 4.6L Mustang Tech
Bolt-Ons...Do I remove them for a Superchager
  • Thread starter Thread starter chalosf
  • Start date Start date Jun 4, 2008
C
chalosf
53
San Francisco, CA
Jun 4, 2008
  • Jun 4, 2008
I'm planning on buying a Vortech supercharger in the near future, my question is: Do I need to get rid of bolt ons like JLT CAI, Steeda UDP, 75MM so the S/C will fit correctly?
Kurgan
3,028
Palm Beach Gardens, FL
Jun 4, 2008
  • Jun 4, 2008
You should still be able to use your existing throttle body and I believe you're okay with the UDPs, too. You will probably have to remove the CAI. Your inlet plumbing is going to get changed around a little bit.
If you have a timing adjuster, you'll probably want to take that off (you don't want too much advance up at the high end with boost) and you'll need a tune -- you can have all your timing programmed in there.
BennyBlown2v
1,233
Carmel, INdiana
Jun 4, 2008
  • Jun 4, 2008
Get rid of the UDP's, they will underdrive your accessories and thus your blower, and you'll make far less boost than you're supposed to. Also, your CAI will no longer work, so sell that as well. The 75mm throttlebody will be fine, also a plenum would be good too if you can afford it.
Kurgan
3,028
Jun 4, 2008
  • Jun 4, 2008
Good call. Didn't even think about that. See what us N/A guys know about superchargers?
You could probably still run the smaller accessory pullies on the other devices, I guess, but you'd need to go back to the stock crank pulley/balancer.
scupking
1,186
Enfield, CT
Jun 4, 2008
  • Jun 4, 2008
That is correct.
C
chalosf
53
San Francisco, CA
Jun 4, 2008
  • Jun 4, 2008
Thanks guys.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
