SPEEDYLIFSAVR Founding Member Sep 18, 2000 666 0 16 FL,89 LX 5.0 Mar 21, 2006 #1 Mar 21, 2006 #1 If the chiltons manual says the torque specs for a bolt are 39-54ft/lbs is that a range? or do you first torque them to 39 then 54?
dragnazz5.0 My "0" key d0esn't w0rk, s0 I have t0 use the zer0 Nov 19, 2005 815 5 18 mooresville, nc Mar 21, 2006 #2 Mar 21, 2006 #2 its a range that you can torque them too. just make sure that all the bolts are torqued in sequence and to the same spec. its more about being even and torquing in the right order than anything
SPEEDYLIFSAVR Founding Member Sep 18, 2000 666 0 16 FL,89 LX 5.0 Mar 21, 2006 #3 Mar 21, 2006 #3 cool , thanks man
