So here’s the story.
I’ve got a forged bottom end 302, stroked to a 342 and afr 185 heads, built initially for nitrous.
The motor was originally built for a track driven 82 mustang. That car frame had some issues so it was time to pull everything and go into the new car. A 92 LX.
I’ve recently switched over to the FiTech EFI from a demon carb.
Anyway, in this swap I’ve debated going to a centrifugal blower setup and getting away from the spray. Here’s the problem, the motor is 10.5:1 compression. I’m not well versed on boost. Doing research, high compression and boost is a no go running pump gas. The issue is, the 92 is gonna get street driven some. Not just a track dedicated car.
Sooooo, my question is, should I stick with the spray or make it work with some type of boost and what kind of risks am I taking going to boost. Running a race fuel doesn’t make sense to me to drive on the street. and I really don’t wanna crack into the motor.
From what I’ve read, if I run boost on it 4 pounds and dropping some timing is about my only option to drive it safely. If that be the case, I’m not sure that it’s worth the extra cost for a blower.
So bring on the thoughts and opinions.
