  • 1994 - 1995 Specific Tech
Boost Question
  • Thread starter Thread starter FlyBy763
  • Start date Start date Nov 28, 2005
FlyBy763
439
Palm Bay, FL
Nov 28, 2005
  • Nov 28, 2005
So I know going from a stock intake to an aftermarket one you will lose some boost, but how much? Im making about 5 pounds right now, does that seem right with a stock 6-8 lb pulley? or do i have bigger problems?
94gsl5.0
223
seatown
Nov 29, 2005
  • Nov 29, 2005
Check your belt could be slipping.... How high are you revving?
FlyBy763
439
Palm Bay, FL
Nov 29, 2005
  • Nov 29, 2005
5500ish...Not real high.
94gsl5.0
223
seatown
Nov 29, 2005
  • Nov 29, 2005
My set up when similar to yours was yeilding similar boost numbers as you at 5500 with a slipping belt and the stock SC inlet. Once the belt was tightened i was seeing closer to 8 and 9#'s at 6000 rpm's.
Are you using the stock tach to judge rpm's? I have found mine was reading higher than the motor was actually turning.
Anywhich way.... You should see lower boost with a better intake manifold.... and thats a good thing More effiecient = more power with less heat.
v6v8swap
113
Oklahoma
Nov 29, 2005
  • Nov 29, 2005
I agree with this. Less boost isn't always a bad thing. More airflow potential equals better power. One of the magazines, sometime in the recent past, did a test that was something like this and they made more power with less boost with a free-er flowing intake system. Having said that, I would def. make sure you're not losing some psi to a slipping belt etc. You don't want to lose power that way after investing in a SC'd setup.
Phil
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
