boosted stock 5.0
My turbo is about 100x more violent than my blower was. Although my combo is put together to be instant spooling and make peak power by 5200 to save the stock block. :)
My blower made 383trq and my turbo makes 612trq at comparable RPMs.
Well you were clearly making a lot less power with the blower setup. If you're making similar numbers it's a much different story.
So me building an AOD car with a blower is going to feel lame?...Should i just go turbo?...I mean I already have the blower on the car its an older Paxton SN93 which us the upgraded vein so its making 6-7 psi plus i just bought an UPR powerpipe to help with boost..Plus its going to have GT40 Heads and gt40 Intake 1.7 cobra rollers..42 Lb injectors ,90mm ligthing MAF, Walbro GSS340 255 lph pump, SCT chip, areomotive Adj fuel regulator...And im sure im for getting tons of stuff..Will i be able to run 12's at least with this set-up?:shrug:
Man all these power adder people wanting to swap back and forth... I'd be happy with any kind!
x1000
im like 98% stock (stopped using the spray) and i love the car but its begging to be faster. hell ive still got the 2.73s in it.
:uzi: 2.73
ill take whatever i can get my hands on.
You guys think that's bad... 95stang... Nitrous...90 eclipse...turbo...01 lightning blower...00 volvo s70...turbo....88lx... Gunna be a bottle
I got a thing for power adders
Posted via Mobile Device
is it worth the money to go with a v-3? or a procharger in terms of being self lubricated? any benefits?
edit: hell ill just keep asking questions. intercooler OR aftercooler?
no oil lines, if your engine blows, **** wont go into the blower.. other than that its the same lol..
i say screw the centrifkul, go for some snail love and be making some serious torque, and upper rpm powa!!
im wanting to go s/c because its simple. a lot of my friends have turbo cars ( ricers:nonono:) and all they do is bitch about tuning and spark maps and fuel curves and blah blah blah.
centri+ fuel mods + sct = :nice:
im not anti-turbo, just anti-constant headache.
No headaches...u can still tune your car via SCT or twEECer and run a turbo. The major reason they (ricers) complain about that is so they look cool. With the right supporting mods you run a decent amount of boost from a turbo, make damn good hp, tremendous amounts of tq and still have room to play later in the game.:shrug:
Here's my buddys mod list....
1989 LX 5.0
Engine/Fuel:
Stock Bottom End 302
Lightly Massaged GT40P heads (Trick Flow Spring/Seal kit)
Trick Flow Stage 1 Cam
FRPP Cobra Intake
C&L 76mm MAF
42# Injectors
Holley Adjustable Fuel Pressure Regulator
FRPP Valve Covers
On3Performance Single Turbo Kit (T-70) -
Mild Steel Hotside - 304 Coldside + DP
Hallman Pro-RX Manual Boost Controller
Walbro 255lph In-tank
AC/Smog Deleted
Alternator Relocate Bracket
Bishir Racing Cat-Back - 3" to Dynomax Bullet Muffler
Drivetrain:
Stock Flywheel
King Cobra Clutch
Tremec TKO500
MGW Short-Throw Shifter
FRPP Aluminum Driveshaft
FRPP 3.73 Ring and Pinion
Suspension:
Strange 10-way adjustable shocks and struts
Steeda LCAs
FRPP UCAs
UMI Performance Torque Box Reinforcement
Urethane Bushings
Front Sway Bar delete
