Bought 89 LX Mustang
  • Thread starter Thread starter l3lue
  • Start date Start date Apr 26, 2007
L
l3lue
32
  • Apr 26, 2007
Hey guys,
I bought a 89LX mustang and there's a few issues...I was wondering if anyone here had any ideas..
Autometer tach jumps all over the place after about 3k
Turn signal doesn't work but hazards do
Car idles really rough and will stall when cold - (will be cleaning out IAC shortly)
cenok is family
1,409
69
79
Norman, Ok
Apr 26, 2007
  • Apr 26, 2007
retrace the wiring for the tach and make sure it's all hooked up correctly and no worn out wires and such. if everythings ok then the tach is probably bad. turn signal problem makes me think the switch on the column is bad. not sure if your car is actually surging but check out this thread...has a lot of idle fix's.
http://forums.stangnet.com/showthread.php?t=534062&highlight=surge+checklist
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Apr 26, 2007
  • Apr 26, 2007
Most likely the green signal wire or the ground for the tach issue.
Idle could be many things start with IAC.
Turn signal Switch.
Enjoy
Unstable Performance
cenok is family
1,409
69
79
Norman, Ok
Apr 26, 2007
  • Apr 26, 2007
Turn signal Switch.
Enjoy
i beg to differ with your sig!
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
