Bought an 87 GT...problems and questions!!!
I am pretty convinced that something bad is wrong. The last time it overheated it was less than 10 minutes after I filled up the radiator. When it overheated the temp was way up so I couldnt even see the needle anymore. I checked under the hood and it was overheating into the overflow tank. No leaks. i waited until it cooled off, filled the radiator back up and finally got it home (5 more minutes). When i got there it was hot but not overflowing yet. this morning i drained the radiator and barely any water came out. Less than one bottle of the collant was in the radiator. and there was barly any water on the ground.
ninety15.0 said:
Well thats your problem right there. You need a t-stat or else that water does not stay in the radiator for long enough to effectively cool down. Replace it with a nice mr. gasket 180* t-stat and see what happens. If you are consistently blowing white smoke i would also look hard at a cheap rebuilt/gasket set. you can just re-ring and bearing it for well under 1.5k...like u said u could afford. Even make some improvements...good luck
i dont think having no t-stat would cause the engine to overheat. it would just take forever to get up to temp, but it shouldnt have any overheatting problems.
I agree with jete, sounds like a likely head gasket failure.
I also agree with vristang that pressure testing the cooling system is in order before you go tearing the engine down.
Out of curiosity, what all has been done to the engine that you know of? Does it have a stock intake, heads, and headers? I'm just curious if the guy you bought it from was BSing you about the cam. Usually people don't put a bigger cam in an otherwise stock engine.
Good luck, let us know what you find.
Jeff
the engine mods include crane cam, k&n, flows, and I think thats it. Im pretty sure there is an aftermarket cam in there. When the engine is on the whole engine shakes but when reved up sounds smooth. It also has the crane cam sticker on the fan shroud.
I will try to get the heads off today and see how the gaskets look.
Foxfan88 said:
if your going to go as far as "check" the head gaskets, it would seem it would be a good idea to go ahead and swap em out while your there lol.
yea thats what I was going to do. Arnt you suppose to change any gasket once it is opened? I will probably change the valve cover gasket and maybe the exhaust manifold gasket. I think they sell them in kits.
Rather than a cam, the rough idle may just be the timing off, that's what was up with my 5.0 when I bought it. I set it back to 10-12 and it smoothed out and idled much better.
Its funny that you say that. While I was taking the engine apart to look at the head gaskets, I noticed that the distributor was a little loose and I could turn it with my hand. I am not sure if that got turned at some point but that would definitly be a cause to the rough idle.
1FatPony said:
im not sure. how can you tell?
If you still have speed density, there should be a plastic tube that runs from the air box (where the filter is) to the throttle body. If it has been converted to mass air, there should be a cast aluminum peice right after the air box, with a electric sensor bolted to it and a wiring harness attached. I'd post a picture, but I don't have any before my SC install.
Jeff
1FatPony said:
its has the aftermarket k&n
Here's a picture with the MAF circled in red at the bottom. Ignore the chrome intake pipe and stuff. If you have that sensor between your air filter and engine, then it has been converted to mass air. If you don't have that sensor, you still have speed density.
BTW, I just snagged this picture from google, don't know whose it is or where it came from.
Jeff
Something tells me the previous owner installed the cam, did a poor job reinstalling the heads, probably didn't torque them right, popped a HG, and pulled the t-stat out in an attempt to cure the problem, then yelled obscenities for a couple days and decided to sell the car to 1FatPony
BTW, speed density setups don't really respond well to some cams. Do you know which Crane Cam is in it? If it's running like crap it's probably not a speed density friendly one
