BOUNCING SPEEDOMETER NEEDLE
  • Thread starter Thread starter fdv91
  • Start date Start date Jun 12, 2008
F
fdv91
  • Jun 12, 2008
I HAVE A 91 NOTCH AND THE SPEEDO NEEDLE BOUNCES WHEN DRIVING ALSO IT'S NOT READING CORRECT DO I CHANGE THE CLUSTER OR SPEEDO GEAR.????
1993SSP
1,194
Ky
Jun 12, 2008
  • Jun 12, 2008
I would start with the speedometer cable first, thats has always been the culprit for me, you might as well pull the cable and check the gear on the end at the tranny while you are at it, check to see if it needs replaced as well
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Jun 12, 2008
  • Jun 12, 2008
but anywho, I have the same problem with mine.... thought it was just the gear and bought one. when i pulled it it was mint, so it must be the cable. I just dont really want to take it all apart yet lol
speaking of which.... anyone have a writeup? thanks
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 12, 2008
  • Jun 12, 2008
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jun 12, 2008
  • Jun 12, 2008
more than likely the cable.
monte87
876
18
49
new york
Jun 12, 2008
  • Jun 12, 2008
speedo gear....
BB 91' NOTCH
md
Jun 12, 2008
  • Jun 12, 2008
I had to replace the cluster,but i would change the cable and gear first.
Scorcher2005
883
South Carolina
Jun 12, 2008
  • Jun 12, 2008
on my first 91 gt (not the one in sig) the needle bounced frrom 0-140 mph. It bounced less and less as you got close to 60mph and from there on it worked fine. I fixed mine though...i just didnt drive under 60mph ;-)
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 13, 2008
  • Jun 13, 2008
Speedometer cable replacement for 87-93 Mustangs.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
The VSS equipped cars have a speedo cable with a different fitting on the transmission end of the cable. It is the fitting on the LH side of the following picture.
Speedo cable housing assembly with cruse control
Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
Speedo head cable clip
Photo courtesy of Almost Stock
6.) With speedo cable removed from the speedo head, try twisting the cable end with your fingers. If it turns more than 1/4 turn, the cable may either be broken or you have damage at the other end where the cable mates to the VSS sensor or speedo pickup gear in the transmission.
Outside the car, replacing the cable housing assembly. The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
7.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
8.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
9.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
10.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
11.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
12.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
13.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
14.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
15.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
16.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip.
Inside the car:
17.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
18.) Reconnect all the wires & connectors on the speedo head unit.
19.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
20.) Re-install the cover for the ignition switch & turn signal.
21.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
Reactions: fredfifty
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
For Sale Ford Motorsport 160 Mph Speedometer - $325
  • TTSaleen
  • Nov 5, 2026
  • Interior Exterior Parts
Interior Exterior Parts Wednesday at 9:22 AM
TTSaleen
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Electrical 93 Foxbody LX 5.0
  • TheJay806
  • Nov 16, 2024
Fox 5.0 Mustang Tech Nov 23, 2024
GTOreturns
G
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
