'95 GT w/ABS: the Brake line junction under the master cylinder, I think it's the Brake Bias Valve.
Anyway, it leaks brake fluid at the front where a hex with a rubber seal is in the center is located.
What is this part called?
How do I fix it? Is it a remove & replace?
Weird thing, the brake pedal has been firm - so it's not sucking air. Brakes work fine - just loosing fluid.
Thanks!
Bruce
Thanks!
Bruce
