Brake bleeding
Shouldn't have to do it with the engine running. I bled brakes on my '90 Mercury just fine.
What procedure are you using? It took me a while to figure out how to bleed brakes properly. My original technique was off.
Motor off ,it really takes two people . Pump pedal until it pumps as high as it will ,have someone open the bleader while keeping pressure on the pedal . When the peddal pushes to the floor ,stop when you feel resistance or you will trip the valve , close the bleeder and let the pedal up . You may need to repeat a few times for each wheel ,checking master cylinder level as you go
