Brake Booster Questions
  • Thread starter Thread starter TrophyHead
  • Start date Start date Jul 31, 2004
TrophyHead
1,195
11
49
PA
Jul 31, 2004
  • Jul 31, 2004
I'm leaking brake fluid. It's coming out right where the Booster bolts to the master cylinder. Is there supposed to be a gasket or seal located there? Or am I just supposed to the tigthen it up really good?
If anybody has any advice on if I should buy a new one...should I get a 94-95 Cobra BB or 93 or V6 Mustang? I still have rear drums but someday I'm gonna take the axels and all off a Lincoln Mark7 and bolt it right to my car. So if I need a new one I'd like to upgrade now to the 2 port design and have all that done untill I convert to a 5 lug rear disc. I've put the 73mm calipers up front.
Any advice would be cool. Thanks
dastang2
2,020
tx
Jul 31, 2004
  • Jul 31, 2004
get a new master cylinder
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,113
224
Massachusetts
Jul 31, 2004
  • Jul 31, 2004
Your MC is leaking from the rear. There is no fluid exchange between the MC and booster, all that's there is a rod that pushes the MC. The MC is leaking inside the bore.
Might be time to choose your MC based on future brake mods.
TrophyHead
1,195
11
49
PA
Jul 31, 2004
  • Jul 31, 2004
Yeah maybe the MC is clogged up. I'm taking everything apart right now. Maybe I'll find something. Anybody else got any info about the gasket or anything?
TrophyHead
1,195
11
49
PA
Jul 31, 2004
  • Jul 31, 2004
Thanks for clearing me up Mike.
Man those brake lines on the MC are really tuff to get off. I'm using a line wrench but there already stripped.
dastang2
2,020
tx
Jul 31, 2004
  • Jul 31, 2004
2 words, vise grip. or cut them off and replace the lines anyway
R
ratrapp
510
buena vista,va
Jul 31, 2004
  • Jul 31, 2004
if your m/c is leaking it needs to be replaced,you'd better do it soon as i've seen some m/c leak back into the booster then you have to replace the booster as well.
trbkrb
1,976
Houston, TX
Jul 31, 2004
  • Jul 31, 2004
Ditto. That happened to mine after the third blown MC. The booster had enough brake fluid in it to slosh around!
If you want the Mark VII rear brakes, with the 73mm fronts, then go with the SVO or Mark VII MC since it is sized for that exact setup. And, you realize the stock Mark VII axles and brackets are 1.25" wider on each side, right, limiting your wheels to 8" at the most? And that looks a bit too wide IMO as it is. But you can modify the brackets like Mike and I did and use the Ranger 5 lug axles to keep the same width as stock.
Good luck!
Thomas
TrophyHead
1,195
11
49
PA
Aug 1, 2004
  • Aug 1, 2004
Good luck!
Thomas
Yeah not alot of people dont like the Mark VII axels on a stang. But I'm gonna be running the 17" Bullit rims and they are only 8 inch wide.
Oh I got the lines off the PV much easier.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
Brakes ATS brembos and drums
  • 5ptslow
  • Nov 16, 2025
Fox 5.0 Mustang Tech Apr 4, 2026
AeroCoupe
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
