Brake Fluid From Rear Caliper At Parking Cable Bolt??
Grn92LX
Fidanza Man!
6,819
64
129
New York
Just finishing up a 5 lug conversion. Started bleeding the brakes today and found fluid leaking from the parking brake bolt that holds the lever. Parking brake isn't hooked up yet if that matters.
Why?
Wash the caliper up well and see if fluid still leaks from this area. Could just be overspill from hooking it up or bleeding the brakes.
If it is still leaking, then use the caliper as a core and go get a reman. You can get the caliper alone (no pad support bracket) for under $30 plus core off rockauto.com.
