citius3:
I have a pressure bleeder and it works well. The generic adapter plate from Motive Products does leak if it is not clamped on squarely to the master cylinder. You can make a custom adapter using a second master cylinder cap and a shrader valve (the same type that is installed on your wheels). This is much less likely to leak. You should know that the master cylinder can be bled, too. The Haynes manual ($18) has a good (but a little generic) write-up. You will need about 3 or 4 containers (pint?) of "Ford Heavy Duty Brake Fluid" (high quality, low cost -- kind of a pleasant surprise).
