There is a difference of opinion as to some but, you could keep your stock booster and get a 95-96 COBRA MC w/ a 15/16" bore. The other option is to get a booster/MC from a SN95 car and do the swap that way. You will also need plug # M-2450-A for the front of the stock PV, as well as, an adjustable PV. MM will also sell the fitting you need for the front brake lines. Don't forget about parking brake cables and to weld the paw of the stock handle. This is a basic idea having just glance at the site. This is of course assuming you already have 5-lug spindles and axles / brackets.
seems kinda pricy, but it is all there as far as the brakes go and you get brand new parts.
You will need everything to convert over to a 5 lug system like said in the above posts. Might also check to see if you ca get slotted rotors as well. good luck
The baer kit is for the most part, the same thing. Instead of Cobra or running pony logos on the front calipers, it says BAER and they charge you more.
