  • SN95 4.6L Mustang Tech
brake line leaking
  • Thread starter Thread starter stangJunkie04
  • Start date Start date May 22, 2006
stangJunkie04
44
Vernon, CT
May 22, 2006
  • May 22, 2006
I was losing pressure in my brake pedal yesterday, and the brake pedal seemed spongy so i thought I had air in my system. I went to bleed the brakes and found that there was brake fluid all over my driverside front wheel well and my brake line was leaking at the copper crush washer seal. So I replaced it an did a ops check and it was fine. But i was just wondering with only 20k on the clock what would cause that copper seal to go?
Nater
239
Maplewood, MN
May 22, 2006
  • May 22, 2006
Could have been a bad part or the bolt was not tight enough and worked itself loose.
T
Torinalth
952
Clayton NC
May 22, 2006
  • May 22, 2006
i'd be on the line of not being tigght from the factory. that just seems a little off. unles you routinely drive over cinder block pieces that get thrown around the inside of the wheel, i'd gues at it being a factory issue.
T
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:17 AM
keel
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Sponsored New J&M Release: 2024+ S650 Full Front + Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Mar 6, 2026
MRaburn
Sponsored New Release: 2024+ S650 Brembo Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
MRaburn
