Brake Line Leaking
  • Thread starter Thread starter 1991RWHP
  • Start date Start date Feb 10, 2009
1991RWHP
59
Illinois
Feb 10, 2009
  • Feb 10, 2009
I just recently did a Wheel Cylinder on my car. Ever since one of the lines is just constantly dripping fluid. Can anyone tell me a fix or tell me how im :Zip2: dumb :Zip2: and messed it up?
Thanks Ahead of Time
Beasty306GT
671
Oxford,Mass
Feb 10, 2009
  • Feb 10, 2009
did u tighten everythng up?? hows the flare on the brake line?
1991RWHP
59
Illinois
Feb 10, 2009
  • Feb 10, 2009
Yea everything is super tight, its when i press the brake the fluid is just oozing out, its leaking between then line and the flare.
LiquidGT
368
Near STL hell
Feb 10, 2009
  • Feb 10, 2009
Is it happening on both sides?
Did you check to see if the flare on the end of the line was messed up?
1991RWHP
59
Illinois
Feb 10, 2009
  • Feb 10, 2009
The flare looks fine, its just weird how its leaking on in between the line and the actual fitting. Everything is tight but when i press the brake it still drips a little fluid, but enough to notice.
Its only leaking from the one that i did... the other side is fine and not leaking.
axeman
1,348
Elizabethtown, PA
Feb 10, 2009
  • Feb 10, 2009
If you're sure it's tight, maybe there's a small crack or the flair is messed up. If there is enough line, you could trim a hair off and make a new flair. Brake line bends pretty easy. Not sure, but you might be able to rent the flair tool from Advance Auto, etc.
Beasty306GT
671
Oxford,Mass
Feb 10, 2009
  • Feb 10, 2009
was the nut rusted to the old cylinder?? it could be anything...i would take it apart again check the flare and check the cylinder for something inside it not letting it seal completly..the flare but could be cracked...the brake line could be cracked.....if it was me i would check everything and if its bad i would just go buy a new piece of 3/16" brake line and bend it and replace the old one making sure the flares are good...and double check the connections for tightness
1991RWHP
59
Illinois
Feb 11, 2009
  • Feb 11, 2009
I just tried cutting off the old flare and redoing it, but the same thing happens. I don't know what the deal is but its really starting to annoy me. The fitting looks fine, just really destroyed now that I've gotten to it and tightened it so many times.
93 LX
3,081
Norwalk, CA.
Feb 11, 2009
  • Feb 11, 2009
bad cylinder or bleed screw is bad...
axeman
1,348
Elizabethtown, PA
Feb 11, 2009
#10
  • Feb 11, 2009
  • #10
Maybe the threads are messed up on the new wheel cylinder. Surely wouldn't be the first time.
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 9, 2026
Cassiebaebae
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 7:51 AM
AlexM556
A
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
