Brake Line Leaking
1991RWHP
59
Illinois
I just recently did a Wheel Cylinder on my car. Ever since one of the lines is just constantly dripping fluid. Can anyone tell me a fix or tell me how im :Zip2: dumb :Zip2: and messed it up?
Thanks Ahead of Time
The flare looks fine, its just weird how its leaking on in between the line and the actual fitting. Everything is tight but when i press the brake it still drips a little fluid, but enough to notice.
Its only leaking from the one that i did... the other side is fine and not leaking.
If you're sure it's tight, maybe there's a small crack or the flair is messed up. If there is enough line, you could trim a hair off and make a new flair. Brake line bends pretty easy. Not sure, but you might be able to rent the flair tool from Advance Auto, etc.
was the nut rusted to the old cylinder?? it could be anything...i would take it apart again check the flare and check the cylinder for something inside it not letting it seal completly..the flare but could be cracked...the brake line could be cracked.....if it was me i would check everything and if its bad i would just go buy a new piece of 3/16" brake line and bend it and replace the old one making sure the flares are good...and double check the connections for tightness
I just tried cutting off the old flare and redoing it, but the same thing happens. I don't know what the deal is but its really starting to annoy me. The fitting looks fine, just really destroyed now that I've gotten to it and tightened it so many times.
