Brake Pedal Switch Removal/Replace
  • Thread starter Thread starter 88GTStreetRod
  • Start date Start date Aug 7, 2004
88GTStreetRod
376
USA
Aug 7, 2004
  • Aug 7, 2004
The switch connected to my brake pedal assemble that controls the brake light illumination is not working properly. My brake lights do not come on until the brake pedal is almost fully engaged. How do you remove and replace this switch? It is very hard to see. I can see the electrical connection going to it and thats ablut it.
Asha'man
1,909
Denver
Aug 7, 2004
  • Aug 7, 2004
There's a small red cotter holding the switch onto the shaft...yank that and then you can pull the switch out. Look carefully when you take it out. The U-shaped side will go back on first, with the full O-shaped one on the outside, then the washer, then the cotter. I'd describe it better, but I only know what it looks like upside down , and it's been a while anyway.
Ash
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Aug 8, 2004
  • Aug 8, 2004
Most of the switches can be adjusted by bending the metal bracket (you'll have to take it out to see what I mean). They get bent otu fo shape if working aroudn them or an alignment guy putting the bar around the brake pedal, etc. Not unheard of to have to tweak it...a new one will surely have to have the same thing done.
88GTStreetRod
376
USA
Aug 8, 2004
  • Aug 8, 2004
Thanks, i think I got it fixed. I also sprayed a little wd40 on the spring, it mad it easier to move and more sensitive.
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
