Brake Problem
  • Thread starter Thread starter Funhog
  • Start date Start date Jun 13, 2005
Funhog
219
Alabama
Jun 13, 2005
  • Jun 13, 2005
I just saw a black spot by my rear passanger tire. I crawled underneath and looked at my tire and there is black crud all over the inside of my wheel, wheel well, and there is also black liqued on my inner part of the tire. I am guessing its brake fluid. What could be the problem? Also, could this be the reason why my brakes squeek or is it just the brakes telling me I need new brakes? Thanks
:damnit:
silverstripes
81
monroe, LA
Jun 13, 2005
  • Jun 13, 2005
prolly either rear wheel cylinder or axle seal.
Funhog
219
Alabama
Jun 14, 2005
  • Jun 14, 2005
anyone else or is that it?
flyinghi3
313
Manorville, LI
Jun 14, 2005
  • Jun 14, 2005
i would have to say axle seal. did you happen to remove the rear drum too see what the condition of the back brake looks like. i think by remove the drum you would be able to see where the leak would be comming from a little better
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jun 14, 2005
  • Jun 14, 2005
What does the black liquid feel like. If its thick and sticky, then its probably gear oil from the axle seal. If its thin, then its probably brake fluid from the wheel cylinder. Any kind of fluid on the brakes would definetly be a bad thing. This is not necessarily what is causing the squeek though.
Funhog
219
Alabama
Jun 14, 2005
  • Jun 14, 2005
Are either of these fixes expensive?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 14, 2005
  • Jun 14, 2005
No.. both of the mentioned failures are pretty common. You can probably find a shop that will do the dirty work for you for around 100 to 150 depending on how much they charge for labor.
Edit: You can check to see if your diff is low and you can look at your brake fluid... That will tell you which one is leaking without taking off the drum.
Funhog
219
Alabama
Jun 17, 2005
  • Jun 17, 2005
Turns out that the problem was the axle seal. Thanks guys. Could this be a reason why I am getting a jolt when the car shifts (detailed in another post called "What is it")?
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
