Brake problem
Stang_Dude
Odd situation here... after driving for 10 or 15 minutes, my car feels like the brakes are partially activated -- like there is some resistance. I've verified this by pushing (rolling) the car in the garage before and after driving it, and there is a big difference -- I can't push it after. When it cools back down, it rolls freely.
Also noticed that after a 30-min highway drive, if I touch the brake pedal it feels like it sinks in a bit more before working. Sort of like when brakes overheat. As a test on my daily driver (Audi), I left the handbrake up a couple notches to add a very little resistance and drove for 10 minutes, then when I pressed the brake pedal I noticed the same behaviour -- the pedal sank in noticeably more before actually stopping the car. So same effect and due to heating of the fluid, etc.
So how would I fix this? If one caliper is stuck, that wheel should be hot to the touch after a drive, but I cannot notice any difference.
Could it be due to exhaust heat under the master cylinder? My exhaust pipes go sideways out the car -- straight from the heads to the side of the car passing under the MC. But then again, it hasn't always done this.
( This is actually a kitcar with basically Fox mustang rear suspension and Mustang II front suspension. Front brakes are Mustang II discs, and rear are thunderbird turbo-coupe discs (the conversion kit from SSBC) on the Fox 8.8 rear. MC and brake booster are stock Fox ).
-Neil.
