Brake Proportioning Valve question
javier302
48
ok, after i did my brakes, and bled them, they worked fine for a day or 2, then i realize that when i open the reservior the small part (rear brakes) was half empty, i found that on the front of the Brake Proportioning Valve there is a small leak on the front nut.... where can i get just that part.
thanks
Maybe remove the nut, cut it off, slip on a new nut, re-flare the tube, and see if that doesn't fix the leak. A new flare nut fitting costs about a buck at most parts stores, but a new proportioning valve is NOT cheap by any means.
Kind of reaching here, but you might even try a little Teflon tape on the nut you have on there right now to see if that helps things. Clean the stuff off with brake cleaner after re-assembly so you can see if there's any fresh leaks.
