Ok, I just installed some 73mm calipers and cross drilled and slotted rotors. I bleed everything out good and I still seem to have a slightly spongy pedal. It'll lock the front tires up evenly still but just not a hard pedal. The pedal is near the top but spongy if you really stand on it. Maybe its normal?
Also it seems like the fronts lock up real easy but the rears wont even think about locking up. Would an adjustable proportioning valve fix this or do I have a bad rubber line at the rear axle?
I read on here to swing the caliper so the bleeder is in the 12 o'clock position and then bleed them. I used a vacuum bleeder and they've always worked good for me.
