  • 1994 - 1995 Specific Tech
Brake question
  • Thread starter Thread starter ISUrb33
  • Start date Start date Jun 9, 2008
I
ISUrb33
30
Longview TX
Jun 9, 2008
  • Jun 9, 2008
Ok, so while i was out of town someone managed to hit a curb in my car and now my rear driver side wheel makes a rubbing/scratching sound with each turn of the wheel. I replaed the rims in case they were bent, replaced all 4 rotors and brake pads in case they might have been bent. I am out of ideas. I was thinking maybe an axle was bent but im not sure. id gladly take any advice you guys might have. thanks.
Also, I upgraded the rotors with Baer OE rotors and the car seems to stop slower than before, any ideas? thanks.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jun 9, 2008
  • Jun 9, 2008
Lesson #1: NEVER let anyone else drive your car. Even if you're in the car. There have been WAY too many Mustangs lost because they let a friend drive their car. While this was a minor bit of damage (compared to totaling the car), it could have been worse.
You could have a bent axle. I had that happen on the donor car for my current Cobra conversion. The wheel didn't look bent, but it would hang up every time the wheel rotated around. I took off the wheel and the caliper & rotor, put the car in neutral and had a friend slowly rotate the other wheel. I could then see the axle wobbling slightly - it was definitely bent. I suggest you give that a try and see if the axle is bent.
Bosko5.0
1,067
longwood, FL
Jun 9, 2008
  • Jun 9, 2008
usually if you bend a axle in an accident the housing is bent too. happened to me, i believe it can be bent back if bent.
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
L
05GT brakes on a 98GT?
  • lparsons42
  • Sep 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2025
lparsons42
L
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
