brake upgrade info
06s197
houston Tx
I was wantin to know has anyone put gt calaipers and rotors on a v6 and if so is it a direct bolt on or do I need to modify anything for them to fit ? my plan is to install front and back rotores and calipers on my 4.0 . Any suggestions are welcome .
The GT's and V-6's use the same calipers and pads. All you need to do the front brakes are GT rotors and caliper mounting brackets. I just did this to my '07 this afternoon, it took less than an hour. I'm pretty sure the V-6 and GT's use the same rear brakes. You will also need to use a 17" wheel to clear the bigger rotor/caliper setup.
