The Brake Warning light receives its input from two sources. The E-brake handle and the low fluid sensor in the Master Cylinder correct??
Reason I ask is because today I was out driving in a "spirited" manner and decided to come off an onramp and brake hard from 60MPH to a dead stop. Halfway during the stop the Brake Warning light came on and lasted until 1 second after i came to a stop. The ABS light did not come on at all.
Obviously the E-brake didn't get pulled so i am just thinking the fluid in the reseviour was sloshing around and tripped the low fluid sender. The Brake light doesn't tie into the brake system in any other way correct?
I checked the fluid level and it was filled to the line. Pads are halfway worn down.
