BRAKES (all you know who im talking too)
  • Thread starter Thread starter 86GT-Top
  • Start date Start date Mar 23, 2004
86GT-Top
244
Bergen County, NJ
Mar 23, 2004
  • Mar 23, 2004
If i buy this, this is the entire conversion kit for the 3-2 port, right? I'm only upgrading the front to 73mm Calipers, Caliper Sleeves, Braided Lines, Hawk pads, drilled slotted rotors. Just tell me if im goin at this right:
No Cut, No flare Conversion kits:
'94-98 V6/GT & 93 Cobra Kit $25.00* -- for use with the '94-98 V6/GT 1 1/16" bore vacuum boosted units and 93 Cobra 1" bore master cylinders. Best all around value for price, size and pedal feel with rear disc or drums and most all front calipers! Use the 93 Cobra for a softer pedal feel when running an aftermarket cam rather than the 94-98 GT/V6 unit.
So this is the conversion and all i need is the Master Cylinder from a 94-98 v6/gt or 93 cobra? which one do you all recommend? THANKS!
86GT-Top
244
Bergen County, NJ
Mar 24, 2004
  • Mar 24, 2004
anyone?
hllon4whls
BANNED
2,567
Covington
Mar 24, 2004
  • Mar 24, 2004
Guess everyone thought that you were talking to someone else.
ttt
86GT-Top
244
Bergen County, NJ
Mar 24, 2004
  • Mar 24, 2004
ttt
Lol, yea, where are the brake masters!!!
BlackFox5.0
3,514
Massachusetts
Mar 24, 2004
  • Mar 24, 2004
The '93 Cobra is a good choice for those calipers. Stick with solid rotors, there is absolutely no advantages of using drilled/slotted rotors on the stock brakes. They are just for looks, and they are much much more prone to cracking/warping. Save yourself the money.
djk8705
154
Fairfax, Va
Mar 24, 2004
  • Mar 24, 2004
Ya save that money. mine are a little bit older then a year and they are cracking like crazy!....
86GT-Top
244
Bergen County, NJ
Mar 24, 2004
  • Mar 24, 2004
ok so a 93 cobra M/C and that 2-3 conversion, i want stock mustang rotors right, i dont need different since there going with a bigger caliper do i?
4. *Upgrade the front calipers to 73mm SVO units.
Get the 73mm calipers with a steel piston if you can. They are usually denoted in the part numbers with a "S". If not the phonemic will work fine on the street. Get the calipers for a '91 Lincoln Mark VII for a direct bolt in (other 86-91 Lincoln's should all have the 73 mm calipers, 86-91 Crown Victorias and 84-86 SVO 4cyl Turbo Mustangs). Here are the part numbers the remanufactured Bendix parts:
I would need to buy pads for the caliper i bought (EG if i want with the 91 Lincoln Mark VII caliper, i need 91 Lincoln Mark VII pas) correct?
86GT-Top
244
Bergen County, NJ
Mar 25, 2004
  • Mar 25, 2004
ttt
BlackFox5.0
3,514
Massachusetts
Mar 25, 2004
  • Mar 25, 2004
I reused my pads since they were still good. All you have to do is CAREFULLY bend the prongs on the back of the inside pad so it fits in the piston. If your rotors/pads are good, then just reuse them. The 73mm calipers are the same as the stock ones, except for the bigger piston so everything you have in the front now is reuseable, when you need to replace something, just use stock parts, like the rotors, and pads.
86GT-Top
244
Bergen County, NJ
Mar 25, 2004
#10
  • Mar 25, 2004
  • #10
Thanks alot BlackFox, i was hoping one of u guys with your Brakes/Rims in your avatar would answer. So in 2 weeks i can put in my 3.73's (from 2.73's), a week after that a shift kit, and then the week after that brakes, a happy april for my car!!!
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Mar 25, 2004
#11
  • Mar 25, 2004
  • #11
Haha, is that what we are known as?
86GT-Top
244
Bergen County, NJ
Mar 26, 2004
#12
  • Mar 26, 2004
  • #12
lol, i think so, i mean you see someone showing off something like that, then HOPEFULLY they know what there talking about. When your posing about brakes there should be a function that sends it directly to all of your guys computers and flashes on the screen, lol!
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Brakes Need help ID’ing which brake lines and seals I need
  • AnthonyA1234
  • Apr 2, 2025
Fox 5.0 Mustang Tech Apr 14, 2025
limp
