  • SN95 4.6L Mustang Tech
Brakes.. HELP :)
  • Thread starter Thread starter Dave_93stang
  • Start date Start date Jun 26, 2005
D
Dave_93stang
24
Westminster,Md
Jun 26, 2005
  • Jun 26, 2005
Hey
I replaced the rear brakes with slotted rotors new calipers and new pads this morning, upon putting them back on my buddy who was working on the other side of the car for some ODD reason removed the Spring that hold the parking brake cable guide in place. I for the life of me can not move this spring back into place... and surely don't want to drive it that way.. especially since it isnt even tagged yet and I need it to pass inspection..
How can I press the spring back into place? I looked and he basically took the bolt that holds it in place out so he could tighten up the rear caliper bolt as the brake like and this spring was in his way.. Oddly I had no problem on the other side..
If need tools I don't mind running to Sears if someone responds before they close today
02GTKB
122
  • Jun 26, 2005
did you release the handle brake?
D
Dave_93stang
24
Westminster,Md
Jun 26, 2005
  • Jun 26, 2005
Yeah it is released.. it has been the entire time.. originally this was just suppose to be a pad and rotor swap.. now its starting to be a PIA..heh
E
exindust
329
Moorpark, CA
Jun 26, 2005
  • Jun 26, 2005
i just painted my rear calipers and i couldnt figure out which bolts to take off, i looked at that one which was spring loaded and thought to myself " wow if i take this one off i probably wont get it back on, its spring loaded it cant be this one "
So common sense saved me.
For you situation... just try moving it and contorting with pliers it to line it up and shove the bolt in ASAP
D
Dave_93stang
24
Westminster,Md
Jun 26, 2005
  • Jun 26, 2005
Yeah, I got out my Old Brake plyers for drum breaks.. Worked great and got it on.. only one problem I tightened the bolt in and it freaking snapped off below the opening.. so now the spring isnt on and I have a broken bolt.. Anyone know if Home Depot carries Left handed Drill bits?
D
Dave_93stang
24
Westminster,Md
Jun 26, 2005
  • Jun 26, 2005
Ok...
OK here is one.. If I cant get the spring back on, if I buy new calipers can I buy new ones and do these springs come on the new Calipers? cause at this point I am definately not above buying new calipers (could always use new ones anyway) to resolve this
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
