Brakes
  • Thread starter Thread starter candphall
  • Start date Start date Oct 6, 2011
candphall
488
32
49
Orlando Florida
Oct 6, 2011
  • Oct 6, 2011
Ok experts I have a 69, standard discs in front drums in rear. All new lines, master cylinder, and wheel brake parts including powerbrake booster. Master cylinder bled on bench. Brakes bled at each weel untill I had what I thought was about a full pedel, this was with out the car running. Started the car up hooked vacum to the power brake booster and pedel went to the floor no brakes and they will not pump up. Turn car off and pedel returns to about where it was with no power. Is it necessary to bleed with the power brakes:shrug booster working.
robbz28
775
Epps, LA
Oct 6, 2011
  • Oct 6, 2011
Is there a hissing or whooshing sound when you press the pedal to the floor with the booster hooked up? if so you may have a bad booster, i know you said its new, but it happens. Also test your check valve on the booster, it may be bad.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Oct 6, 2011
  • Oct 6, 2011
My '84 was off when I bled the brakes and I had no problems.
M
MitchGT
204
Oct 6, 2011
  • Oct 6, 2011
if you turn off the engine, does pedal feel return?
candphall
488
32
49
Orlando Florida
Oct 6, 2011
  • Oct 6, 2011
It returns some what but still not great. I guess its back to bleeding.
R
Rmoore45
142
Oct 6, 2011
  • Oct 6, 2011
Did you adjust the actual brake shoes? If the adjuster is all the way in, you would not have very good brakes.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Fox Brake Pedal
  • Realmongo
  • Nov 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2025
Realmongo
