break fluid disapearing
Good morning all,
I got in my 94 gt this am and the break light came on, master was almost dry. This happened about 2-3 weeks ago.
Brakes work fine, is a daily driver. There are no visible leaks, master cycl, prop valve, all calipers dry.
No brake pedal fade and the booster is airtight.
I am wondering if anyone has had similar issues, am guessing it is master. I do not know alot about the ABS system, maybe could be going somewhere else????
Any help would be appreciated,
Thanks,
John
Well it has to be going some where maybe around the abs box (just infont of the rad on the passenger side). Put some cardboard down at night at possible places is would leak. Spray everything down with some carb cleaner (it removes oils and evaporates(sp?) almost instantly(sp?). Before going to bed go hold the brakes down for a while (a few minutes) to build pressure in the lines. I don't think it leaking on the inside becuse you would be able to smell it, but hell check the carpet for dampness you never know good luck.
