broke the plastic tip on one of the fuel injectors..
JimTMich
161
Michigan
I was doing an intake swap and one of the injectors flipped out onto the intake manifold and broke the plastic yellow tip. The injector still functions fine, but will the spray pattern be messed up enough by this to warrant finding a used injector from stangparts.com or just run it?
I had this same thing happen two weeks ago and I freaked. I then found out that the rebuild kit has a new cap, 2 new orings and the plastic washer/spacer. For $20 you can replace all the caps and orings (recommended anyhow). Turns out for me it was a good thing that it fell out, oring was ripped and I would have never known unless I pulled the injector from the rail.
Try Napa...This is there kit...3-4 bucks
