So I was changing the thromostart and flushing the rad, got everything done, and in the process of screwing the thermostat housing back into the engine block it actually cracked and broke, apparently I overtightened the drivers side bolt.
Do you fellas know if the t-stat housing from a Fox 5.0 is the same as ours? I found a parts data base online that says the part number I am looking for is a FOZZ-8592B, which is the same as the part for a Fox 5.0, however, the T-stat housing from my GTS says its a FOZE-8594A.
The picture I found on the net looks identicaly to the part I'm looking for, but I'd like to be sure.
thanks in advance,
adam
thanks in advance,
adam
