broken air injector tube
DShort
I removed the mid pipe and was trying to get the tube off coming from the smog pump and broke. I have shorty headers to go on and a X pipe with the tube capped off already, but I had planned on using the smog pump since the car is stock. What should I do?
You can't do this
You can't do this
If I get another piece of small pipe welded in. I broke my air injector tube about 3" inches from the exhaust pipe tube, it might be to hot in that area and melt/burn the rubber is what I meant.
3" is plenty. That rubber can take the heat. I have mine hooked up like that and it's prob only 3" away.
It is heater hose...which is designed for 200* coolant to pass through.
