Bucking in 5th gear only...
  • Thread starter Thread starter Loco5.0
  • Start date Start date Dec 20, 2004
L
Loco5.0
Dec 20, 2004
  • Dec 20, 2004
Car sometimes bucks in 5th gear. It will only do it in 5th and if I give it a good amount of gas when it does it it seems to lessen it.
Thoughts?
HISSIN50
34
129
Dec 20, 2004
  • Dec 20, 2004
what revs are you turning in 5th when this occurs?
i would surmise you are at low revs (if you have stock gears) and there is a tiny bit of surging, etc which is exacerbated from the low revs, lack of torque and throttle input.
my two cents - more info would help. good luck.
L
Loco5.0
Dec 20, 2004
  • Dec 20, 2004
About 2500 RPMs I believe. I'll check again the next time I drive it. 3.55 gears
battyice
153
West Chazy, NY
Dec 20, 2004
  • Dec 20, 2004
More info would help, but I would start by checking your ignition components. Old plugs & wires can cause symptoms like you're describing.
L
Loco5.0
Dec 21, 2004
  • Dec 21, 2004
Plugs have under 2k miles on em & wires only a little more.
L
Loco5.0
Dec 23, 2004
  • Dec 23, 2004
Drove the car yesterday & RPMs don't seem to matter, but it looks like she only wants to do it when under light load
TrophyHead
1,195
11
49
PA
Dec 23, 2004
  • Dec 23, 2004
How's reverse?
Your gonna need to drop the tranny to be sure. Probably a worn synchro or bent 5th/reverse shaft.
I recommend you buy a Tremec.
L
Loco5.0
Dec 23, 2004
  • Dec 23, 2004
TrophyHead said:
How's reverse?
R is fine. It's jus the bucking in 5th sometimes
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Engine Light throttle miss
  • Dontknowchit
  • Jul 7, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
AeroCoupe
