Ok so it looks like we need to re-do some of the idle settings with the new heads, the initial values are no longer correct for the higher mat temps after you did all those pulls.@a91what this thing died finally while i was data logging... do you see anything weird. i know my fueling looks weird im still working on it. i found my regulator had a lot more pressure than necessary so i adjusted it and am working through that now....
just didnt know if you seen anything weird where it kills itself at the end of the log
Its sounds like he maybe a HP junky
If it was me I would probably turn the boost down 1-2 psi just until you get the fueling under control and then off to the dyno.
