Build Opinions?
Konnect
First of all i would like to introduce myself, im 22 years old born and raised in central florida, i grew up around cars and racing, weekend short track ovals etc., i have built and driven many cars, mainly GM, but i also ran FWD dodge 4pots for awhile, more recently i am trying to get into SCCA and grassroots type stuff, but in order to do that.. i need a car :D, my options as of right now are.. a 97 Prelude Type SH, or an 85 GSL-SE RX-7 with a blown rotary
the obvious choice, atleast im my opinion.. is the RX-7, but rather than rebuild the rotary, i decided to take the kiddy gloves off and put some torque under the hood, i have already gotten the answers i need in order to put the 5.0 into the car, though i still have alot of questions that will get answered along the way im sure
right now, i have a 5.0 and a 3spd auto, the goal will be around 250-275ftlbs, since thats all the stock rear end will safely hold, i want to keep the engine as light as possible, will it be lighter in the end EFI or carb? im going to use aluminum GT40 heads in order to keep the engine mostly stock and as light as i can doing so, also.. if i do put it in the car with the automatic trans, and switch to the 5spd, i wont have to change anything will i?
another concern of mine is gear ratio
1st 3.622:1
2nd 2.186:1
3rd 1.419:1
4th 1.000:1
5th 0.760:1
Final Drive 4.080:1
Ring gear 4.076
thats how it is stock..., with 195/6014 and a T5, what will happen? o.O
car will also be striped as much as i can, lightest seats i can find, aswell as battery relocation and all that jazz, and yes, it will be driven on the street aswell
i would like to hear any suggestions any of you might have, about anything really, how i should configure the engine(efi/carb/heads/trans) etc., i know the gearing depends heavily on what exactly i will do with the car, but i also want to be able to drive it on the street without getting horrible gas mileage.. thats probably to much to ask though
thanks for letting me waste your time!
Choice for the car is a no brainer, rx7.
Stay efi no matter what.
Put it in with the 5 speed now and be done with it.
Most automatics suck the life out of a 5.0.
If you are using gt40 aluminum heads, use the X's and have them valve jobbed before they go on the car.
I'd also be looking for a gt40 tubular intake to go with them, along with a 65mm TB and spacer.
carb is going to be 15+lbs lighter and less expensive but obviously the gas mileage will be down considerably.
Are you ever going to use some type of forced induction?
That would really only affect the cam choice . . .
the gt40 aluminum heads can be cleaned up to make decent power, and along with a ported gt40 or cobra intake you should be able to make 280-290rwhp with a stick and a OTS cam.
I am assuming the auto is a c4?
In a light car with the right converter, the car will be just as fast if not faster at that point.
You're going to make way more than "250-275" ft-lb with a 302 and aluminum heads...
Should be a sweet device, though. I've known of other piston-driven RX-7s, and the results are always entertaining. Good luck!
im not sure what the transmission is, it had an AOD-E on the engine that was burnt up, the guy gave me a working auto just to get it going in the car, all i know is the linkage turns 6 times, so i assume thats 1 2 D N R P
im going to try and keep the engine as stock as i can, i just want it to be a tight little drivetrain that isnt going to overpower the chassis, the rearend will be the weak link, since i have seen them break with 300ftlbs to the rear tires, i dont want the car to be a complete monster(yet) i just want a solid fun little car, it was great with the rotary in it.. just had no low end grunt, i would have been happy with the rotary if it only had torque
i figured a carb setup would be lighter, none of the wiring and extra manifold size, i know EFI is better in most cases, but i may just stay carb for awhile, i will probably go with a Megasquirt conversion when i get a new rear end
if i get the driveshaft made with the auto in it, i can still switch to a T5 without any problem cant i? and also, i found some GT40P heads, whats the difference with the exhaust, i heard you need different headers
which is another problem ill have to address.. short headers or find longtubes that will fit the chassis, headaches await me!:nice:
Can't you find a cheap Ford 8.8 or 9 inch rear end that you can throw in it and not have that worry? Thats what I would do, seems like you could source one from a junkyard car or off Ebay for cheap.
The GT-40P heads have a different spark plug angle/location, so header design is different. There is a thread hidden in one of the tech stickies that talks about those heads, as well as other GT-40 stuff that you should take a peek at.
Later.
i would like to put a 9" ford under it, but im pretty sure it would have to be cut down some, im not sure how wide it is, i know the track width of the rx-7, 1420/1400 mm (55.9/55.1 in) front/rear, the body is 1670mm (65.7 in) wide, i want it to remain as stock as possible, i could easily get a 9", infact i just sent a housing to the scrap yard out from under a dirt latemodel
ill have to do some checking and find out what i can do, anyone know the exact width of a 9 inch ford?, the rear end in the car now has disc-breaks and an LSD in it, probably work good for the track if it held up
can anyone tell me what this transmission might be?
i found a place i can get a rebuilt 8.8 thats ready to bolt into the car for $1750, in my choice of gears and choice of trutrac, detroit locker or a spool, or $2295 with a torque arm conversion included
thats alittle out of my budget for just the rearend at this point, though its good to know i can get one later, once im done with the car and save up alittle more again :nice:
9 inch rears are overkill for almost any project these days.
Built 8.8's will handle 7 second ET's so, just a use an 8.8.
Look for a tag on the transmission, then type it into google.
If it turns out to be an AOD or AODE do yourself a favor and don't bother using it for anything.
Unless you have a built version (which is very expensive) all the trans will really do is slow you down, then probably blow up.
Adding a shift kit and converter to one of the above makes a major difference, but those parts also mean you just invested a t5's worth of money into the automatic transmission.
i havent found a tag yet, ill give it the once over again, im pretty sure it is an AOD though sadly, i will be using a T5 once i can find one to get, a local junkyard is a sponsor for my racecars, i can get stuff there for next to nothing, he just doesnt have any T5s in right now
im going to buy one of those built 8.8s, i just have to wait until i have the car done, if i blow my budget on the rear, then find out i need something else, ill be in trouble lol, so far though its all going smoothly
thanks for the input so far!
