- Nov 3, 2004
- 48
- 0
- 6
Hey guys , looking for some advise on building my new engine
i already have the following
bored block
eagle stroker kit w/ forged srp pistons
trick flow twisted wedge heads
1.7 rockers
what type of cam should i get
i was thinking the COMP CAMS XTREME 270 HYD
Intake Duration at 050 inch LiftVL: 218
Exhaust Duration at 050 inch LiftVL: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake DurationVL: 270
Advertised Exhaust DurationVL: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm RatioVL: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm RatioVL: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
Lobe Separation (degrees)VL: 114
or
XTREME ENERGY 274
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 286
Advertised Duration: 274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.520
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.523
Valve Lift with Factory Rocker Arm Ratio: 0.520 int./0.523 exh. lift
Lobe Separation (degrees): 110
looking to make around 450hp flywheel
any advice ?
also the pistons i bought the kit with have the oil ring coming through where the wrist pin is .. is this a problem with 331 ?
thanks !
bored block
1.7 rockers
or
XTREME ENERGY 274
any advice ?
thanks !
