I want to build a fuel injector tester to clean out my injectors. Want to make sure I'm doing this right. Am I correct with this setup as I drew it up with the injector connector taken from an injector harness, with an alligator clamp going to the negative terminal on battery, and from the positive terminal another alligator going to the momentary switch, and completing the circuit from the switch back to the injector connector? And by doing this I'll be able to pulse power on and off to the injector safely without ruining the injector or killing myself? Thanks!
