  • 1994 - 1995 Specific Tech
Building New Combo (Need Advice)
  • Thread starter Thread starter mackey
  • Start date Start date Jun 18, 2004
M
mackey
1,284
Beverly, Massachusetts
Jun 18, 2004
  • Jun 18, 2004
Well I have some graduation money to build a new combo but I have some questions about sizes etc. My end goal is to run a 75-100 shot of nitrous through the engine.
Combo
Trickflow Kit (I heard it doesn't come with lifters. If it is true which should I get)
190 or 255 intank fuel pump.
AFPR
Pro-M Meter 77 or 80?
Should I get 24 or 30 or 36lb injectors
3.73 or 3.55 Gears.
What guages should i get to moniter the engine.
Water Temp and whatelse
Thanks for the help in advance!
Joes95GT
3,132
Delaware
Jun 18, 2004
  • Jun 18, 2004
Don't waste your money on gauges. The only thing they do besides tell you something that is unavoidable, is make your car seem "high profile," encouraging more people to break into it because they understand the value of those gauges. Buy a nice radiator and run a strong coolant mix if you are worried about water temperature. The car is going to run hotter with aluminum heads on it, there is nothing you can do about it.
Pro-M 80, calibrated for 24 pound injectors will work best.
You don't need new lifters. As long as your old ones are in good shape, re-use them.
3.73 gear minimum. You may even want to look into a 3.90 or 4.10.
What about the cam?
Joe
zenboy99
2,212
Madison, WI
Jun 18, 2004
  • Jun 18, 2004
What trick flow kit would you get?
Most engine builders recomend getting new lifters when you get a new cam. Almost everyone I know is using the FMS lifters.
If you don't care about the looks of the plastic meter, then definitely get the Pro-M 80mm, its a great meter.
9
94DreamGT
593
Indiana
Jun 18, 2004
  • Jun 18, 2004
If your car has lower miles and has not been raced hard, spending $100+ on a new set of lifters is probably a waste of money.
Pro-M 80 - Don't think you can even get the 77 anymore and it is more $$$ for same performance
24lbs - Shoudl be plenty. If you are planning more in the future, might want to look at 30lbs
Go 255lph pump...can't hurt going bigger and its the same price
AFPR - Get a Kirban
3.73's or 4.10's...your choice. Depends a lot on what kindof driving you are planning on doing too.
HoofnIt
1,175
North Carolina
Jun 18, 2004
  • Jun 18, 2004
I disagree. A good watertemp gauge is a good idea, especially if you like to know what temp your engine is running at as opposed to the vague 'O' in NORMAL. I would also recommend an oil pressure gauge because the factory one is nothing more than an idiot light with a needle.
M
mackey
1,284
Jun 19, 2004
  • Jun 19, 2004
street heat kit. has to pass ma emissions and get me to college everyday.
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
