Built 98 2v For Trade Looking for something Faster
ImageDynamix
597
Wichita, KS
98 GT, ~75k miles. Laser Red, Black leather/Rear Seat Delete, very clean. Mods listed below. will probably forget lots of little stuff, will update if I remember anything else. Bottom end has just a few thousand miles on it, upgrading all the top end stuff right now H/C/I. Just wanna see what else is out there. $10k
284ci
OEM Cobra Crank
Manley Forged H-Beam Rods
JE Forged Dish Pistons(8.9 to 1 cr)
MHS Stage 2 Heads with upgraded valves and springs
MHS Stage 2 PI Nitrous/Blower Cams
Edelbrock Victor Jr Intake
ARP hardware including head studs.
Solid Motor Mounts
Cobra oil pump
7qt canton pan.
Pro. Products SFI Balancer
BBK 75mm TB
6061.com Plenum
C&L Inlet Tube w/K&n
Edelbrock Fuel rails.
FRPP Shorties
Off-Road h-pipe
2 chamber Flowmasters
Flowmaster Tailpipes
Walbro 255 in tank pump.
Aeromotive regulator
Tremec TKO 600
Steeda Clutch cable
Spec 3 Clutch
Steeda Tri-Ax Handle on TKO Shifter
4.10s
Speedcal Box
D&D Tubular K-Member
D&D Tubular Control Arms
D&D Front coil-overs
UPR Adjustable LCAs.
Steeda Rear Springs
BBK Boxed Uppers
CC Plates
Power Stop Drilled and Slotted Front and Rear Brakes
Stock 2001 GT wheels
Rear Seat Delete
Cold Fusion Wet Nitrous Kit with PREDATOR Nozzle and 15# Bottle
SCT XCAL2 with Brenspeed Tunes.
Everything works, AC, Cruise, factory mach stereo
Also have a set of painted black Weld Prostars (15x8 and 15x3.5) with BFG Drag Radials that could be included for the right deal.
Looking for a modded clean fox or pushrod sn95. perferably a power adder car, blower, turbo, ect....no junk. Prefer aftermarket block cars. Motor is coming out as we speak, will check it all out and add all the MHS/Edelbrock Top End stuff and put it back together asap. Pics available on request.
Wichita, KS
[email protected]
