Bullitt Springs
  • Thread starter Thread starter calstud1028
  • Start date Start date Oct 21, 2007
calstud1028
12
California
Oct 21, 2007
  • Oct 21, 2007
Was wondering if anyone has tried to put Bullitt springs on their V6 mustang. If not, what do you think about putting those on, would they work, and would they drop the car noticeably?
Skymarshal
572
Dallas
Oct 22, 2007
  • Oct 22, 2007
The Bullitt springs shouldn't be used for lowering a car, since they only drop the car about 1/2" over stock, and they shouldn't be put on a V6, since their spring rate is calibrated for the heavier V8 engine in the front.
A number of companies carry springs that will drop a V6 about 1". That's about where you want it- gets rid of the 4x4 look, but won't require castor/camber plates or look too "slammed". Their spring rate will be correct for the V6, too.
5-SpeedStallion
230
Tampa, FL
Oct 22, 2007
  • Oct 22, 2007
V6's can benefit from higher spring rates, just like any Mustang can. However, the stock spring rate on a V6 is significantly lower than the 600lb/in (front) Bullitt springs, so the stock dampers won't offer sufficient damping to take advantage of the higher spring rate. Then again, the same could be said for putting Bullitt springs on a stock GT.
Overall, you need to consider your goal... Are you going for looks or performance. If you're wanting the slammed look... the Bullitt springs aren't going to do it for you. On the other hand, if you want to add handling w/o a large drop, look for the Bullitt suspension kit which will come with the springs, Tokico shocks/struts, and sway bars.
Ebay Lowering springs
  • Canyonred86
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
3.27 to 3.73 worth it? (Automatic)
  • skidad
  • Nov 4, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 5, 2026
nickyb
Adding subs with mach 460 system
  • 2v.cjmullis
  • Sep 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
gkomo
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
