  • 1994 - 1995 Specific Tech
bump steer kit ?'s
  • Thread starter Thread starter CArkid0101
  • Start date Start date Apr 6, 2005
C
CArkid0101
76
Meno Falls, WI
Apr 6, 2005
  • Apr 6, 2005
bump steer & C&C kit ?'s
hey, first off this is prolly an easy question to 90% of you out there but what does a bump steer kit do? When do you need one? What differences are there between after market bump steer kits? And how do they work?
Second thing, cast and camber kits, same questions, what are they, what do they do, when do u need one, differences, and help would be awesome
Ive seen people getting rims then getting them at the same time to, is it needed if i get bigger rims? Once again, thanks for the help - Andrew
stang22
1,318
Washington, D.C.
Apr 6, 2005
  • Apr 6, 2005
Straight from Maximum Motorsports site:
“Bumpsteer” is a term for the situation where the front toe changes as the suspension moves up and down. If the toe changes more than a very small amount it will cause the car to change direction, making the car unstable and unpredictable.
Here is a link that will tell you everything (hopefully) you want to know about C/C plates.
http://www.maximummotorsports.com/cc.asp
LoudToy958
435
Bremerton, WA
Apr 6, 2005
  • Apr 6, 2005
There are two other threads on here- the above info is great, the other two threads have before and after pics, and explain the difference when used. They are recent, and both have bump steer in the title. Hope these help.
http://forums.stangnet.com/showthread.php?t=532759
http://forums.stangnet.com/showthread.php?t=532702
rude_life
372
  • Apr 7, 2005
i agree with both of you guys and from my understanding, bumpsteer can be defined as the various bumps and uneven parts of the road steering your car rather than you steering your car
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
